Old 02-06-2007, 10:22 PM
Rwillia4's Avatar
Rwillia4 Rwillia4 is offline
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
Default Brake line routed thru fender
Skip- if a wheel is lugcentric I'm not sure a hub ring should be helping, as this would center the wheel on the hub. In any case, if it is lug centric then tighting the lugs in a "skip every-other lug" pattern finger tight, then light torque, then final torque should center the wheel around the lug pattern.
I'm not sure if this is standard or not. Armond at Cal Cobra routed my brake lines thru the fender wall and then down, to keep the header heat from saturating the brake fluid. With this I'm not sure if I would still need the brake shield that Ed makes.
Route from the master to the fender and where they come together below on the frame:
Here is what it looks like in the fender well (with a cover to protect the lines):
