Old 02-10-2007, 05:11 AM
coosawjack's Avatar
coosawjack coosawjack is offline
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
I have a slight vibration in my CR at 1200 RPM that returns at about 2400 RPM with a fully balanced engine that I doubted was the culprit??
I found that the side pipes are causing it since they are attached to the frame just in front of the back wheels!! Unbolt them and take a short spin to see if that is your vibration (harmonic) source??
I made some heavy rubber "Donuts" to help isolate the side pipes from the frame and they helped quite a bit!!
I can send you a couple to try if you like!!
Coosawjack
