Old 02-10-2007, 07:14 PM
J Persons J Persons is offline
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
This is a Wilwood pull type slave, using a T5Z, and a SBF. The slave connects to a bracket that's bolted to an Energy Suspension motor mount. The shaft rides in the original hole in the bell housing and I used the plastic end of an old Mustang clutch cable as a bushing. The piece of stainless all thread and coupling nut I sourced from www.mcmaster.com. The slave works very well with a 1" Wilwood master cylinder.
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
