Old 02-12-2007, 01:33 PM
Fastblueoval Fastblueoval is offline
Originally Posted by cdnus
I can't find any mention of a 2.90 1st. on his site. Is this a fact??
As I have a aluminium T/L on order & I would like to have it if available.
Craig
Here you go mate!
2.44 / 2.90 First Gear
DK296-41A $125.00
5.000 lbs
33 Tooth first gear can be used in all wide and close ratio Toploaders to lower the first gear ratio. In a wide ratio Toploader first gear will change from 2.78 to 2.90. In a close ratio Toploader first gear will change from 2.32 to 2.44. If you want to have better low end performance without changing the rear end gear ratio this is the perfect solution.
The cluster gear does not have to be changed to use this gear.
