Old 02-13-2007, 07:54 PM
lineslinger's Avatar
lineslinger lineslinger is offline
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
d ford,
If you can't get your camera to focus on the numbers try using a mirror, holding it at a proper angle, you may need some help, then photographing the reflected image of the casting numbers directly from the mirror.
Once you load it into your computer you should be able to zoom into the casting numbers within the picture and then post them, it might help by allowing someone to actually see the numbers.
