Old 02-19-2007, 09:23 PM
67JET's Avatar
67JET 67JET is offline
Cobra Make, Engine: Holliday Motorsport/396 GM / 4 speed / Jag rearend
Default Hydrualic clutch (one more time)
I started a new thread last night but i can't find it. I need to know about a hydrualic throw out bearing. The directions say to shim it until it is against the clutch fingers. To actually pre-load the bearing a little bit. This means that the bearing will be turning all the time. I think it will burn the bearing up if it turns all the time with the clutch. As hard as it is to get my trans out, I don't want to do it any more than i have to. It is maade by SouthWest Speed and is identical to a Howe.
