Ivan,
Not a bad idea, especially if you have the extra roll bar, which is also a good idea. I've noticed that if I put my arm up over the back of the cockpit, it cuts down on wind buffeting considerably and have thought about making some kind of a clear plastic shield, too. Seems to me I've seen such an installation but I can't recall where. It should be an easy installation and probably worth the time and trouble. If you do this, it would be great of you to post photos here.
Incidentally, my wife's Miata has a similar device which flips up with the top down and down out of the way with the top up.
Enjoy your car and your trip.
Lowell
edit: Jeez...both of you guys posted at the same time, a minute before I hit the button. Excellent suggestion: absolutely order a pair of Rob's jack stands and a scissors jack. The stands are too pretty to use but you'll be glad to have them if you have to do anything under the car when you're on the road.
