Old 02-22-2007, 08:24 AM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
That is a definite improvment over what you initially had, but it is still a really big loop. Your driveline will still flop all over the place if a u-joint does let go. I think it would be better if you could significantly reduce the overall inside diameter. 1 or 2 inches of clearance between your driveline and the loop all the way around would be ideal.
Chris
