Old 02-22-2007, 11:59 AM
RedBarchetta RedBarchetta is offline
Banned
Originally Posted by Blas
The more I look at the photos, the more I think that one properly sized and placed ring would do the trick. Centered on the driveshaft, with a tighter ring to shaft clearance - say .75" maybe. The ring would catch the shaft regardless of which end of the shaft u-joint detonates....
Blas, if I could get my fab guy to rework the outriggers to pull the hoop closer to the middle (would take some iron twisting, or some custom welds), along with my previous thought of cutting down the lower portion of the hoop so that it cinches up closer to the bottom of the driveshaft, then I might just achieve the same idea you just mentioned.
-Dean
