Here is what I did with mine this week. Since the drive line is off to the passenger side, I bent the hoop smaller and drilled a new hole in the bottom strap. Then I made the bottom part to keep the drive line from flopping around to much if it does cut loose. I also drilled out the holes and put bigger grade 8 bolts. I am thinking of making another one that is closer to the front Ujoint since the stock one is towards the back. You could use the bolts from the trans cross member so you wouldn't have to weld to the frame or drill holes.
Scott
