If you remove the rocker shaft and the 5 posts ..... If you look I think it was the center pedistal has a
oil hole where the
oil is fed up to the shaft. That little hole in the head ... you need to add a restrictor. I dont think some thing like that is made ??? I used to take a carberator jet and fit it in the hole so the
oil is restricted but not eliminated.
