Old 02-25-2007, 07:19 AM
Ibr8k4vetts's Avatar
Ibr8k4vetts Ibr8k4vetts is offline
Originally Posted by MaSnaka
RLSidwell, How did you determine you have too much oil going to the topside? How do you know if your getting enough after installing restrictors? I am curious because I have wondered the same thing. I have a fe390 block and heads also. Thanks
John
I had a old junk yard valve cover that I cut hole in the top and covered with clear plastic then ran the engine with it installed
Mike Z
