What if....you were to add a plate - for now lets just say 4" square in size...now mentally divide it into 4 -2" squares....you drilled a bolt hole in the center of one of the 2" squares that is the same size as the hole in the tab on the chassie for the existing hoop...now if you put this new plate on the car it would bolt to the existing hoop mount and butt-up against the chassie for the full 4" of plate length opposite the new hole you drilled....you now could move the new hoop to the center of your dtive shaft - you might want the plate to be 4"x6" depending on real measurements....just thinking...
Blas#760
