Old 02-25-2007, 05:04 PM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
My CRII has the battery in the trunk. I didn't put it there as I am the 3rd owner of the car. It's located inside the passenger side wheel well. Held in place by a steel bracket. The cables go through the trunk floor. A short cables grounds to the chassis just under the trunk, a much longer cable runs to the starter selenoid. I think it's called a selenoid. It's not attached to the started directly. The battery posts have conectors with wing nuts so disconnecting is very easy. Two bolts and the braket is loose. I will be changing to a closed cell battery eventually (Optima). Any questions let me know. John
