I will give you a call for the cable Al. If you have any better pictures that would help. As far as the lifter problem, went to the dodge lifters which are bigger, .904" if I recall. bronze lifter bores where added. Jesel is the new lifter with a preoiler before any startup. Jesel said per
oil manditory to pervent failure with a cam over .700" lift. No adjustments or failures with this process being done every start. I would add a lucas
oil suppliment also. Rick L.
