battery
John,
I think fastratxsg had some good ideas. I have a 1993 Classic with two optima mount in the right side of the trunk. Theres room to put a plate under the trunk to bolt the battery case to so if you get hit it doesn:t pull the the bolts thru the friberglass. A cut off switch is a good safety idea to cut the power if you get a short etc,etc. Also a #1 or #2 cable so you dont lose volts to the engine.
Andy
