Thread: Rear suspension
Old 07-16-2001, 09:56 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
The post below this one, same subject, describes rear shock options.
The component procurement manual that came with your kit references a rear shock originally found on a VW, with VW part #. This is where the cross referencing begins.
I cross referenced it to a Koni shock which seems to work OK. Don Scott has a Pro-Shock which also works well. Also discussed were rear springs. Try your auto supply store for the Chevette replacement Moog springs, or Don's springs if the ones you're using are too stiff.
