Old 02-26-2007, 08:44 AM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Note that the Holley jets work fine if you're running cast iron heads. If you're running Edelbrock heads, the jets won't work because the oil passage in the head is considerably smaller. For my Edelbrock heads, I tapped the oil passage, cut a short length of "all thread" and drilled a small hole through the center. I made a screw driver notch in the end and then screwed it down into the tapped oil passage.
Chris
