Thread: Engine Problem
Old 02-26-2007, 06:00 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Colin
I take it you pulled a valve cover to take a look at the rocker arms? and they looked good?
Now I'm by no means a mechanic but it sounds as if the piston hit the plug?
To know for sure you'll need to pull the head and look at the valves and the piston...# 4 on the passenger side.
If the piston is dented you are looking at a rebuild if not look over the head and valves one of the #4 valves will not look right.
Maybe I'm way off base here?
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
