Mass Flow
Mike the picture that you saw had a Fast throttle body on it and used the Fast PCU without a mass flow meter on top of it because it was speed density. My intake had about an 1/2 inch spacer below the throttle body as well.
Have you cut the hood out to the edge of the air scoop. I had to cut the hood out to the very edge of the scoop and then I milled a little of the bottom of the air cleaner where it sets on the throttle body. I then had to put about a 45 degree angle around the outer edge of the air cleaner so it cleared the hood edge and the scoop wheen closed.
Rob my partner had to drop the engine on one of the cars that he was werking on about an 1/2 inch but this was with the stack injection.
How much does your hood likee before it will clear? Thanks, Keith
Keith C
