Old 03-04-2007, 02:17 PM
double ugly's Avatar
double ugly double ugly is offline
There are two answers to the first question. I have always believed that the wire should have a little slack and before venturing out I always checked that there was some slack in all four wires. Others will tell you to have no slack. That doesn't make a lot of sense to me, however.
Using a clip will prevent the wheel for going it's own way. If you do get a wobble stop and tighten the tri-wing.
The spinner, if on tight, won't likely loosen but if it does I think the wire will keep it from getting looser and hopefully you will check the wires before your next trip and find a wire that doesn't have any slack.
John
double ugly
