Old 03-05-2007, 08:37 PM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
Since the 392 stroker is based on a 351W which shares many common parts with the 302 it will be an easy swap. The main thing you will need is new headers since the 351W is wider and taller than the 302 although the two motors share the same cylinder heads. The different headers are necessary in order to keep your side pipes aligned in the proper position. The motor mounts should be the same. All 351Ws are balanced with a 28 oz. imbalance whereas later 302s are balanced with a 50 oz. imbalance. Therefore, the flywheels may or may not be interchangeable unless you are running an early 302 (pre '84). Standard bell housings should be the same and YES you can still use your T-5 tranny especially if you are already using the late model Mustang cable clutch setup with a 157 tooth flywheel and a 10.5" diaphragm clutch. If your flywheel is already a 28 oz. imbalance piece you can reuse it along with the clutch, bell housing, clutch fork, etc. If your present flywheel is a 50 oz. model, simply swap it for a 28 oz. one. Bolt-on pieces such as pulley sets, alternator, water pump, valve covers can all be reused. The starter should also survive the swap. Hope all this helps.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
