Old 03-12-2007, 10:20 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Fuel system for Weber IDA 48 need help
Hello All,
I would like to find out what most of you are using for a fuel system on the IDA 48's. I am currently using the banjo setup and experiencing leaks after awhile, I am guessing from the vibration of the motor even with new gaskets. I was thinking of using AN "T" fittings to get away from the banjo setup. Has anyone used this option? If so what is the size and thread pitch of the Weber Body.
Also, I am currently using a Holley "Blue" fuel pump for this setup. I am not happy with this pump because I am noticing a change in PSI from 3-0 psi and a nasty noise. I have read some post as to the Blue pump leaving people stranded.
I am currently looking into the Mallory 110 GPH or the Aeromotive P/N 11209 90 GPH. Does anyone have any suggestions with these pumps or a different one.
