Pete, we don't use the GM column anymore. We switched to Ididit a few years ago. If you change to the Ididit you will need to change the mount and the shaft length between the u-joints. We also moved the wipers and high beams to the dash along with the ignition switch. So you would need to do some rewiring as well. The GM column is an easy fix to replace the key mechanism. Let me know if you need help and I can walk you through it over the phone.
Don
