Old 03-12-2007, 03:35 PM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
jack, the way the rear tunnel for the emergency brake is setup it will act as a driveshaft loop towards the top of the car. If you want to you can add a strap between the frame rails under the driveshaft to keep it from dropping to the ground.
Don
