Peters44,
What determines safety wire size is the diameter of the hole it will pass through. The wire should fit the hole. Common safety wire sizes are: .020 .032 and .047. For Cobra knock offs I would think .032 would be the minimum and if .047 fits, it should be used. One other thing to keep in mind is to keep the safety as short as possible. In aviation applications, wire runs are usually kept to 6" or less between tie points. Also, a proper safety will have 6-12 twists per inch. It is important not to have the wire too tight (stressed), or too loose.
Gun Doc
