Pete, if you remove the three larger torx screws then you can pull out the turn signal switch enough to get it out of the way. You will also need to remove the turn signal arm. The other smaller torx is what holds the key switch in place. Check the linkage for the lock position to see what's hanging it up. The linkage also controls the locking pin.
Don
