Thread: bore vs. stroke
Old 03-17-2007, 07:28 PM
Dennis Kelley Dennis Kelley is offline
Cobra Make, Engine: BDR 302 AFR 165
Default Rpm
The reason for the bigger stroke than bore is that the engine master challenge only measure horsepower and torque up to 6500 rpm I believe. Its designed to limit the rpms by the rules set forth. If they measured horsepower up to 8000 rpm I believe you would see more shorter strokes but maybe not. The engine builders want to make as much HP/Tq through the rpm range and it would seem that bigger stroke small bore does the trick up to the specified RPM. Just my opinion.
later
dennis
