Thread: Rear suspension
Old 07-19-2001, 11:01 AM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Here's a shot of a set of frame mounts I had made by my welding shop specifically to use new Energy Suspension SBF polyurethane motor mounts. Dramatic improvement in supporting engine and keeping it from flopping around over stock rubber mounts, particularly the MII mounts.
Sent drawings & photos to Pete Johnson at CR. Presumably, CR now sells them. Presumably, DV & DS have something similar. If not, I'll pull 'em back out and make a copy so you can.
Also grafted a BBK late Mustang clutch quadrant to CR clutch pedal, along with BBK cable & firewall adjuster. Cable is stronger & longer than OEM and stays out of the way of the header. Firewall adjuster lets you adj clutch from firewall, instead of having to crawl under car to do it.
