Old 03-18-2007, 05:52 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by PaulProe
Does anyone have any pictures showing the route the lower radiator hose takes on a 427 S/C
My memory is the lower radiator connection is on the pass. side but I can't find any clear pictures of the path taken
If its the same as a CSX4000 car, then the lower hose comes off the bottom passenger side of the radiator, oriented straight across towards the drivers side. Then , it immediately makes about a 30 degree bend back towards the engine, and passes diagonally through the X brace for the front suspension. As it becomes close to the water pump, it bends up and around back alittle, back towards the engine where it connects to the water pump.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
