Old 03-19-2007, 01:45 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Thanks for the words of encourgement.
Its just that every time I try to post a problem about these webers, I never seem to get a response to my questions.
Here is a pretty simple question that I can not seem to find an answer to.....
I am experiencing a problem as well as others on CC, that when you start your motor with webers the fuel pressure starts to fade.
Anwsers
1. Is this normal
2. Is this a bad pressure gauge
3. Is it a bad fuel pump
4. Nobody seems to know the answer
what should the pressure be set too if it fades after the motor warms up. the cold setting or the warm setting. If you set it to the cold setting, how do you know if you are getting the correct pressure when it is warm? And vice versa.
