Old 03-25-2007, 06:44 AM
Rpollard Rpollard is offline
Cobra Make, Engine: Lonestar / 408W Stroker
Default Help, Valve stem hight above valve spring?
Valve stem height above valve springs varies in height, Should the stems have been ground to match the lowest valve stem when heads where rebuilt? It is affecting the push rod length. 1964 427 block, 1964 FE cast iron heads. Comp Cam, Comp solid lifters (none roller) and Roller tip Rockers.
HMIHNTR
Lone Star LSC427, Speed-o-Motive 408 Stroker
2005 Ford SD 6.0 Harley Davidson /Super Chip 425 HP
1975 24' Campbell V-Drive / 1963 427 Ford
2000 Prowler 32' 5th wheel
And the Harley pulls them both to Lake Havasu
