Old 03-25-2007, 06:55 AM
Rick Parker's Avatar
A good shop will set the depth of the valves on the seats as close as possible to each other and then cut the length of the respective stems so that when a machined straight edge is laid across the stems, they are all the same height. Otherwise, pushrod length (as you discovered) will vary considerably causing the valvetrain geometry difficulties.
Rick
