Old 03-25-2007, 09:13 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by wrench87
this is why i get confused on what to do, i set out to build a 427 using all new parts to find out no one makes a new 3.78 crank. with scat i can go 3.98,4.125 or the 4.250 stroke they all cost about the same i wanted a 427 not a 451 or a 468 or a 482. i thought also with the bigger strokers you need a lot more cyl head to feed them the stage 3 heads are over 3k.
An original 3.78 crank cast/steel will be strong enough for normally aspirated engines. As everybody has eluded to, a stroker crank will give more torque/hp in the lower rpm range, peak hp will be at lower rpm, although absolute peak hp may not be that less.
Whether you run a stock or stroker crank, power can be excessive, and acceleration brutal, deadly.
I actually have a stock stroke 427, cast crank, and had it chassis dyno'd, and it surprised me how much torque/hp it made. 488 rwtq @ 3900 rpm's, which is about 600 at the flywheel, more than what I would have expected from a stock displacement 427. I wanted a stock stroke 427, just like it would have come from Ford/Shelby.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
