Old 03-27-2007, 11:35 AM
CobraV8 CobraV8 is offline
Originally Posted by Mike Bartlett
Is pressure the only concern or even with "acceptable" pressure is the rod bearing gap unacceptable no matter what the oil pressure is??
Absolutely, there's a good reason for checking play (i.e. with plastigage) before assembling the rotating assembly. An undersized crank wiht standart bearings will result in wearing out the crank journals quickly.
Simon
