Old 03-27-2007, 11:45 AM
Lowell W Lowell W is offline
Club Cobra Member
Cobra Make, Engine: SPF #1507 427 Dart Block Windsor
Your car is totaled!
I will be willing to purchase it from you for the totaled value.
Dang...Beat me to it!
Seriously, you're not really hosed...just challenged...
I agree with Sal and Ron, with one addition: See whether you can get some plastic pipe plugs or hole plugs of some kind (try MSCDirect, for starters) or the plugs that go in the empty holes on an electrical service panel, and make the hole to fit the plug. That way, when you're done, you can plug the hole neatly and use it to access the nut if the need arises again.
As Jeff said, although sometimes things look pretty bleak right after the "OH $HIT", when you step back and think a little, the solution is pretty simple.
Good luck,
Lowell
