  #21 (permalink)
Old 03-27-2007, 10:47 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by ccx1984
Doug my upper a arm on the drivers side rear stripped when i unbolted it, this is just a 5/16 NC tapped hole in the 1/8" thick tubing no nut on the inside. i plan on drilling it out to 1/2" and inserting a peice of 1/2" round 3/8" long and welding it solid and redrilling and tapping it to 5/16NC, should be stronger than orginal. i expect this to happen a few more times before completion. brought my new side pipes and hedders to jet hot about 75 miles from here, their coating them with jet hot sterling silver cost $295 should be ready 4/6. PS what happend to the measurements for the calipers.
HI, Pete!
I definitely have a nut in there. I can see it moving around on the end of the bolt. I don't have equipment nor expertise in welding - I wish I did. I've been so tied up with trying to get this thing assembled that I never got to the caliper measurements - my bad. Once I get through this "crisis" I'll try to get reassembled enough to get a measurement. Thanks!
Doug
