Old 03-29-2007, 04:16 PM
07cob's Avatar
07cob 07cob is offline
Default Fuel Tank
Originally Posted by hsv300
Hey Sambo got mine from Able Instruments in QLD VDO units white with chrome rings and had the pointers changed to white. I got 7 x 52mm gauges and 2 x 100mm plus senders and fuel tank float to suit Harrison tank for $1000.00 Will add some pics tonight.
HSV300
Have you cut the hole in the tank for the fuel sender as yet? The units Able supply are generally installed from outside the tank, requiring a reasonably large hole to be cut (which may lead to some leaking). I took a risk (after measuring up about 200 times) and cut a smaller hole next to the hole for the pump. This way I could get my hand in the tank to install the backing plate for the unit. I fitted the unit and presto, it clears the baffle in the centre of the tank by a poofteenth and works a treat. With a much smaller hole than is needed to install from outside. I haven't filled the tank yet - just enough to start - so I am still hoping that it doesn't leak.
GeoF
