Pulled the coil wire and tested for spark by using a screw driver and held close to the block and then the sterring shaft, No spark aparent. i looked at the fuse panel to check the fuse for the ignition and could not find one, only for starter and the fuel pump and the chock.am I overlooking something? I have not changed the plugs yet because I want to fix the spark problem first. But I am sure I have glazed the plugs or whatever by now with all the gas I have pumped into it. Is there a fuse for the ignition and were is it?
