it depends on the mounts you use, I used the energy suspension motor and transmission mounts, they had two bolts to the block and one large bolt and a dial pin to the frame mount, I had to build the frame mounts to fit the motor mounts, I bolted the frame mount using the four predrilled holes in the frame, I used a T5 transmission (with the short bellhousing) and a four link Mustang GT rear, my drive shaft is 14" , the dimples where on the jelcoat side of the firewall cowl, I had to modify the cowl frame to make my pedal setup work, I cut the back leg on the drivers side and extended it back to give me room for the pedals, I can give you measurements, however I am working 12 hr shifts and will not be off again until Wednesday
PapaJohn
