I don't think there is a resistor in line to the coil. I followed the wires to the MSD box and nothing. When I checked the power to the coil I placed the test light on the Positive connection on the top of the coil with the other end of the test light clamped to the block. and I tried the negative side as well. I had the key in the on position but did not crank it. Should I repeat this and try cranking it? The box is a MSD,I don't no if it is a MSD-6 or what though.
