Old 04-01-2007, 11:32 AM
Rwillia4's Avatar
Rwillia4 Rwillia4 is offline
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
Default Exhaust Heat Shield Mounting poll
This may sound like a silly question but here goes.... So I'm installing the ring mounts that clamp onto the exhaust, these rings hold the exhaust heat shields in place. They can go on two ways. How are yours mounted? One way the clamping bolts on the ring are on the bottom of the pipe. Flip the ring around and the bolt then sits between the body an the pipe. I the first case you see the bolts walking up to the car, the second way you see the bolts as you get in and out of the car. I can't decide and currently have one side bolts in and the other bolts down to see what I notice more.
Where are yours located? In or Down
