Old 04-02-2007, 08:04 PM
jarendall jarendall is offline
Cobra Make, Engine: StreetBeast 66 replica 302 350HP
I built the brackets myself, used 1 1/2" flat stock about 1/4" thick, the shock that faces rear is supposed to prevent the rear from swaying, it however does not prevent rearend rollup. I had to mount a snubber on top of the rear to stop this problem, when the rearend rolls up the wheels will hit the fenders and the drive shaft universal joints will hit against the rear yoke making a loud noise, it will only do this when you get on the gas heavy, I suggest you install a snubber to start with, I can make pictures of the brackets
PapaJohn
