Old 04-03-2007, 09:36 AM
sexzsn8k sexzsn8k is offline
Cobra Make, Engine: ERA #624 (427 S/C), 428 PI
Robert, using the stock distributor with a Pertronix insert. According to the instructions, Red = ignition switch (White wire, #40, coil to starter solenoid), Yellow = negative coil (Orange wire, #40, coil to signal side of Tach), Black = Gnd and White = Tach output (??????). Using the 427 schematic, Yellow goes to signal side of tach, but where does the White go ? If you go to the Pertronix site, installation instructions for Rev Limiter/non-HEI, it will explain the layout. Sure could use your help. Thanks.......
If you want manners, drive something else....
COBRA's are ALL about EXCESS !
