go_sf Who's lifters are you running? I would tell you to go to the FE forum and ask the same question. I run crane anti pumpups without any problems. The only thing with them is if you pull the rocker shaft you have to remove all the lifter and get the
oil out of the housings. If you don't the valves will stay open and not bleed down. Rick L.
