Old 04-04-2007, 08:10 AM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
Brent
Since you have a Kirkham...... you will have to drop the fuel tank and weld another bung in the fuel tank so you can return the fuel back to the tank and not interfere with the venting of the tank......
Some will say use the vent and put a tee in the vent line..... not really a good idea.....
If you want to track the car....then you will need a collector for the returned fuel to enter into....... which is where the pickup is ...so the fuel is circulated....and no it does not get heated....
Use a regulator as suggested to regulate the fuel pressure at the carb ....and use a fuel line that is equal to or larger then the pressure side....
Morris
Morris
