When I had my stroker built, I insisted on a BG carb. It has always run rich, even after extensive dyno tuning. I was told by a couple of high HP engine builders who have extensive dyno experience, that replacing a BG with a Holley usually resulted in a performance increase. I figured I would consider sending my carb to an expert to be tweaked and when I found the guy (ex-BG employee here in Georgia) he recommended a 4150 HP over the Mighty Demon.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
