Old 04-06-2007, 04:16 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
Brent,
I did use the second output of a Holley Fuel Pressure Regulator and fed a line to somewhere under the footbox before the line goes into the fuel filter and mechanical fuel pump. The Tee has a restrictor inside with a 1.2mm hole. This way y get the full fuel pressure to the webers, but as soon as I stop the engine the pressure drains away quickly through this "return" line. No need to feed a line back to the tank.
Nothing sounds better than a Cobra in a Tunnel !
