Ford 557 Stroker Kit
Hello, I recently purchased the scat 557ci stroker kit, 4.500 stroke crankshaft,6.700 H-Beam rods and 080 Forged pistons ( 4.440 bore ) as i was planning to rebuild it as a high performance 460ci, I purchased the Ford Racing camshaft M-6250 C460 ( 595/621 Lift ) will this camshaft work with the 557ci kit ? I have the Victor intake 2966 and a 950cfm carb, will the 950cfm be O-K to use now that I will be adding nearly 100 cubic inches, or would I be better off going up to a 1050cfm Holley and the Victor intake 2965 to match the 1050cfm carb. Compression will be 10/5 to 1, Cast heads reworked to SCJ specs 2-25 inlet valve & 1.76 Exhaust, gearbox is a Toploader 4 speed. Thanks Jamie.
