Old 04-06-2007, 02:34 PM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Once you have removed the crank Number one Piston should come out the bottom OK. However given your description I think a full teardown and cleanout of oil galleries etc would be the safer option. If there is any evidence of debris on any of the other rod/main bearing inserts it is obvious that the debris has got past the filter and into the gallery system and if not cleaned out you will only risk further problems.
Jac Mac
